I'm working on a piping system and I initially wanted to change the symbol of a flange fitting to the symbol of a multiport fitting using this code:
FamilySymbol symbol = doc.GetElement(symbolId) as FamilySymbol;
FamilyInstance myMP = myMultiPort as FamilyInstance;
myMP.Symbol = symbol;
That doesn't work, I think, because the fittings are of different types. So, now I'm trying to place my new family instance of the multiport fitting in the same exact spot with the same exact orientation. Placing it on the correct XYZ was easy, but trying to duplicate it's orientation is proving to be difficult. HandOrientation is read-only, as is Facing and WorkPlane.
I've attempted to rotate with X, Y, and Z, but trigonometry was never my subject.
Thanks for any help!
Hi
I may not have an ready made answer for you but here's a few things about your issues.
First of all I assume that the flange and the multiport are different families? If that's the case then you can't mix the family symbols of those in the way you showed us. The closest one to what you have tried is the ChangeTypeId() method which allows you to change the used family symbol of the particular instance. But both (existing and target) family symbols (types) must be under the same family.
So as far as I know, you are on the correct path. Rotating the element to wanted orientation, similarly than the previous element can be sometimes tricky task. You just need to figure it out how to do that. If both elements contain connectors that should be pointin in the same direction, that's a information that you could use also. And yes...you can't use facing orientation etc to rotate the element, you need to use ElementTransformUtils::RotateElement() method.
Hope this has any help for you.
Thanks for the reply. The flange family and the multiport family are identical but for changing the type. If I try the ChangeTypeId(), will that affect other placements of the same family or is it per instance? I'm thinking if I can change the Type to a multiport temporarily, I can then change the symbol to the correct family from there keeping the orientation.
I have it pretty close using the ElementRotate(), but complicated angles still aren't perfect.
Thanks for your help.
