Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
place a family in a family-file / assembly a family out of multiple families
5 REPLIES 5
346 Views, 5 Replies
hey there,
few days ago I started to develop a small project for my company. The goal is it to assemble automatically a REVIT-family out of multiple existing REVIT-families by placing them in a family-document. After that I want to provide that document as a download.
Right now I can open documents and place family instances (in a project file by coordinates) by using an WCF, so I can run it later on the server an call the functions from outside. I tried that to test the API in general. So far I didn't have any problems. But know I tried to place and move the instances in a family-file by simply using the document.Create.NewFamilyInstance function. But it doesn't work in a family-file for me. Right now it's hard to debug because of the WCF.
So my question now, is it in principle possible to "assemble" REVIT families in a family-document? Or do you have any other ideas how I can realize my plans?
Thanks, Marco
5 REPLIES 5
Revitalizer
in Family context, use document.FamilyCreate instead of document.Create.
Best regards,
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
in reply to: Revitalizer
Hey Revitalizer,
thanks for your answer. My fault, I used document.FamilyCreate.NewFamilyInstance already, but it doesn't work.
So to make it clear, I want to place a existing Family within a opened .rfa-file. I think we have some issues with the WCF an it's not a problem of the REVIT-API. But again the question is it in general possible to place a existing family within a family-file by using the API?
Thanks, Marco
Revitalizer
Dear Mail,
do you use the correct overload of the NewFamilyInstance method ?
Since Families can have a different insertion behaviour, it is necessary to use the right one:
http://thebuildingcoder.typepad.com/blog/2013/09/family-instance-placement.html
Cheers,
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Hey Revitalizer,
it seems like I have another problem. I just cleared up my code to the basics and left out the WCF. I'm still not able to simply load a Family. Here my code:
 String FamilyPath = @"C:\Module_800_SEG.rfa";
                Family family = null;
                if (null == family)
                    // It is not present, so check for
                    // the file to load it from:
                    if (!File.Exists(FamilyPath))
                        throw new Exception("File not found " + FamilyPath);
                    // Load family from file:
                    using (Transaction tx = new Transaction(doc))
                        tx.Start("Load Family");
                        doc.LoadFamily(FamilyPath, out family);
                        tx.Commit();
Any Ideas? Evertime I call it, I get a "System.Runtime.InteropServices.SEHException" in RevitAPI.dll. Is it possible to get additonal Information about the error.
Thanks, Marco
Hey there,
I solved a lot of problems over the weekend and now biggest parts of the code do their job. But I habe still one last problem left.
After I placed a family into a new FamilyDocument I want to place the next block right next to the first, the third right next to the second and so on. The width of the blocks can be different, so I decided to use planes in families I place, to find the Point for the next block. But I don't find a way to access the planes via the API.
To make it clear. I want to open an emtpy FamilyDocument(FamilyHost) (check). After that I want to place a existing family (Element1) into it (check). Then I try to place a second family(Element2) right next to the first(looking for a solution). All blocks can have the same y- and z-coordinates, only the x-part is different. Now I modified the Element1-Family, so that it has a plane at its end named RIGHT. After placing the familyInstance the plane is not visible int he Document, but i want to know the x-coordinate of the plane "RIGHT".
Any ideas?
Thanks, Marco
Rail Community
