Jeremy's recent posts about rolling offsets of pipes has been pretty helpful for me to advance MEP importing.
But I get a null value returned from NewElbowFitting without an exception. Can someone please help?
It's possible I need to set something up in the project, I'm not an expert with services by any means.
I've attached sample code and you can download revit project here:
http://geometrygym.wikidot.com/local--files/cloudfiles/140502%20two%20pipes.rvt
Jon
Solved by js1900. Go to Solution.
Hi Will,
Thanks for looking (and the answer is embarrasing). I hadn't detected the place holders, I checked my original code and found the cause and it's now fixed. Appreciate your response.
Cheers,
Jon
