NewCrossFitting nondescriptive exception thrown
I am attempting to create a cross fitting by calling Owner.Document.Create.NewCrossFItting, passing in 4 connectors to pipes that are on the same plane and lie along orthogonal lines.  I've verified that the connectors are all at the same point.
When I try to call NewCrossFitting, an InvalidOperationException is thrown, with a message stating the obvious:
"failed to insert cross"
Are there many scenarios where this exception can be thrown, or does it have one specific meaning?  If the former, is there a way to make a feature request of the revit developers to write exception descriptions that aren't totally useless?
jeremytammik
Dear Davex,
Please excuse this ultra-late reply.
I finally discovered and published the answer on The Building Coder:
http://thebuildingcoder.typepad.com/blog/2014/10/newcrossfitting-connection-order.html
Better late than never, I hope!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
