Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Navisworks Export
2 REPLIES 2
R.van.den.Bor
649 Views, 2 Replies
Navisworks Export
I try this code :
//create NWExportOptions
NavisworksExportOptions nweOptions = new NavisworksExportOptions();
nweOptions.ExportScope = NavisworksExportScope.Model;
nweOptions.ViewId = uidoc.ActiveView.Id;
doc.Export(@"D:\test", @"test.nwc", nweOptions);
But now I get an error saying "A Navisworks Exporter is not available in the installed Revit.."
Is there a way to check if there is ?
I don't want to bypass this message with an try catch.
Kind regards,
Remy van den Bor
ICN Solutions B.V.
Liked this post or found it usefull, don't forget the Kudo It won't hurt (at least not me).
2 REPLIES 2
arnostlobel
in reply to: R.van.den.Bor
Remy van den Bor:
OptionalFunctionalityUtils.IsNavisworksExporterAvailable will do the trick. Hopefully it is available in the version of Revit you have. Probably it is. This one particular method was intruduced in R2014 and the class itself was available even before that.
Arnošt Löbel
R.van.den.Bor
in reply to: arnostlobel
Super, thanx, that's it 🙂
Kind regards,
Remy van den Bor
ICN Solutions B.V.
Rail Community
