Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
mouse over context help
2 REPLIES 2
Ning_Zhou
483 Views, 2 Replies
just wonder if it's doable to customize, default is workset : category : family : type, i'm thinking adding system type for MEP stuff
2 REPLIES 2
jeremytammik
in reply to: Ning_Zhou
Dear Ning,
Happy New Year to you and thank you for your query.
For a hard approach to this, check out the custom tooltip implementation:
http://thebuildingcoder.typepad.com/blog/2012/10/uiview-windows-coordinates-referenceintersector-and...
For a more realistic production level approach, you could implement something similar to Joel Karr's modeless pressure drop tool:
http://thebuildingcoder.typepad.com/blog/2009/10/modeless-pressure-drop-tool.html
http://thebuildingcoder.typepad.com/blog/2009/12/modeless-dialogues-in-revit.html
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Ning_Zhou
in reply to: jeremytammik
thanks Jeremy and Happy New Year too!
i'll give it a try later
Autodesk DevCon in Munich May 28-29th
Rail Community
