which is the mobile that I should use for viewing revit 3d model in mobile and acheive the following tasks:
1.Model can be rotated 360 degrees.
2.Tap on an element and view its properties.
3.Swipe finger along any gridline on the floor plan and the relevant section will pop up.
An Early help/reponse will be highly appreciated.
Thanks & Regards
Dear Punit,
Thank you for your query.
I believe that 360 BIM already fulfils the requirements you list:
http://www.autodesk.com/products/bim-360/overview
Definitely number 1 and 2 are included.
I hope this helps.
Best regards,
Jeremy
Is there not any API/SDK of Autodesk 360 using which I can furthur develop according to my requirements.
Thanks & Regards
sure.
BIM 360 Glue:
Field:
Best regards,
Jeremy
Browsing through the links and the samples couldn't get my hands on any materials relating to development on android platform.
Thanks & Regards
The BIM 360 Glue and Navisworks viewers do include offline viewing capabilities:
Currently, only iOS is supported.
Android support is expected soon.
Here is a blog post providing some more detailed information on the current status:
http://adndevblog.typepad.com/aec/2013/01/viewing-a-navisworks-file-on-your-ipad.html
Best regards,
Jeremy
