If I create a model curve in a massing family document, can I make it a reference line? There is a readonly property for extracting current state. There is also a builtin parameter that looked likely but this didn't seem to work.
This curve is used downstream as a profile for a loft.
Jon
Solved by Revitalizer. Go to Solution.
Hi GeomGym,
there is a method ModelCurve.ChangeToReferenceLine(), does this fit your needings ?
I don't know whether it will function in (Massing) Family context, but the RevitAPI.chm does not mention such a restriction.
Best regards,
Revitalizer
Hi Revitalizer,
Thanks, that is exactly what I wanted, my search hadn't unearthered that method.
Remy, at least in the massing environment, you can select a curve and it has an instance parameter that can convert it to a reference curve.
Cheers,
Jon
