Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Linework Command Overrides
5 REPLIES 5
BobbyC.Jones
876 Views, 5 Replies
Is there a way to get and set line style overrides created with the Linework tool?  Thanks.
Bobby C. Jones
5 REPLIES 5
Katsuaki.T
in reply to: BobbyC.Jones
You can get/set graphic overrides for an element in the view using View.GetElementOverrides and View.SetElementOverrides methods respectively. However, there is no API to control linework of individual edges of the element as Linework tool allows.
Katsuaki Takamizawa
Technical Support Specialist
Katsuaki.T
Unfortunately there seems to be no way to carry over overrides applied by Linework tool to a new view. I tried PostCommand method as following. But CanPostCommand method returns ‘false’. Strangely, it works for creating a dependent view by passing the commad id ID_CREATE_DEPENDENT_VIEW (you can find command ids from Journal file).
RevitCommandId id = RevitCommandId.LookupCommandId("ID_CONVERT_TO_STAND_ALONE");
// Post the revision editing command
if (uiapp.CanPostCommand(id))
uiapp.PostCommand(id);
I looked into ElementTransformUtils.CopyElements method. But this is for copying (copy&paste) elements between views and not for duplicating views. And as I see from the UI, duplicated views do not keep the overrides applied by Linework tool.
I requested the Revit dev-team to allow PostCommand work for ID_CONVERT_TO_STAND_ALONE. The ticket is REVIT-27681.
Katsuaki Takamizawa
Dale.Bartlett
in reply to: Katsuaki.T
A year on... Is there any way to apply the LINEWORK tool to a view? For example, all the cut edges. Regards, Dale
______________
Yes, I'm Satoshi.
in reply to: Dale.Bartlett
I don't think so, I also asked about this back in July. Jeremy put in a request to the dev team about it but I haven't heard any more about it.
http://forums.autodesk.com/t5/revit-api/change-line-style-of-geometry-edges-per-view-linework-tool/m...
lionel.kai
I posted an Idea for this requested functionality here:
API access to Linework tool (get and set edge/line overrides) - Autodesk Community
Lionel J. Camara
BIM Manager at KAI Hawaii, Inc. - Structural and Forensic Engineers
Autodesk Certified Professional
Rail Community
