Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Line Weight Setting
1 REPLY 1
drdanielfc
619 Views, 1 Reply
Line Weight Setting
How would I go about setting the Projection Line Weight in "Line Styles" and "Object Styles" using the Revit API?
1 REPLY 1
BIM.Frankliang
in reply to: drdanielfc
    Change Line style can be supported in Revit 2018, you could try codes below:
var linePatternElements = new FilteredElementCollector(doc).OfClass(typeof(LinePatternElement)).ToList();
var categories = doc.Settings.Categories;
var lineCat = categories.get_Item(BuiltInCategory.OST_Lines);
var subcats = lineCat.SubCategories;
Category matchedItem = subcats.get_Item(LineStyleName);
matchedItem.SetLineWeight(LineWidth,GraphicsStyleType.Projection);
matchedItem.LineColor = new Color(red, green, blue);
var linePatternElem = linePatternElements.FirstOrDefault(x => x.Name == LineStyleName);
if (linePatternElem != null)
    matchedItem.SetLinePatternId(linePatternElem.Id,GraphicsStyleType.Projection);
Note that codes must run in Transaction 🙂
Rail Community
