Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
iterating and editing points from pcg file using Revit PointCloud API
1 REPLY 1
yscgrs
426 Views, 1 Reply
hi,
I'm trying to deal with a pcg file, which is a 3D point cloud format in Revit.
This is what I want to do.
1. get each point in a point cloud
2. change the value of some parts in a point cloud.
In short, it seems that I acquire values of each point, but editing them doesn't seem to work.
Below is the code,
so if have any idea, please help me.
I'm struggling with it. T_T
p,s also, the bounding box of point cloud gets null !!!! why???!!
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
UIApplication uiapp = commandData.Application;
UIDocument uidoc = uiapp.ActiveUIDocument;
Application app = uiapp.Application;
Document doc = uidoc.Document;
Transaction tr = new Transaction(doc, "FailureMessage Posting");
tr.Start();
try
PointCloudType type = PointCloudType.Create(doc, "pcg", @"d:\\test.pcg");
PointCloudInstance pcInstance = PointCloudInstance.Create(doc, type.Id, Transform.Identity);
if (doc != null)
BoundingBoxXYZ boundingBox = pcInstance.get_BoundingBox(null);
if (boundingBox != null)
else
boundingBox = new BoundingBoxXYZ();
boundingBox.Min = new XYZ(-999999999, -999999999, -999999999);
boundingBox.Max = new XYZ(999999999, 99999999, 99999999);
List<Plane> planes = new List<Plane>();
planes.Add(app.Create.NewPlane(XYZ.BasisX, boundingBox.Min));
planes.Add(app.Create.NewPlane(-XYZ.BasisX, boundingBox.Max));
planes.Add(app.Create.NewPlane(XYZ.BasisY, boundingBox.Min));
planes.Add(app.Create.NewPlane(-XYZ.BasisY, boundingBox.Max));
planes.Add(app.Create.NewPlane(XYZ.BasisZ, boundingBox.Min));
planes.Add(app.Create.NewPlane(-XYZ.BasisZ, boundingBox.Max));
PointCloudFilter filter = PointCloudFilterFactory.CreateMultiPlaneFilter(planes);
pcInstance.FilterAction = SelectionFilterAction.Highlight;
PointCollection points = pcInstance.GetPoints(filter, 100000);
System.Windows.Forms.MessageBox.Show(points.Count.ToString());
unsafe
CloudPoint* pointBuffer = (CloudPoint*)points.GetPointBufferPointer().ToPointer();
int totalCount = points.Count;
for (int numberOfPoints = 0; numberOfPoints < totalCount; numberOfPoints++)
CloudPoint point = *(pointBuffer + numberOfPoints);
System.Drawing.Color color = System.Drawing.ColorTranslator.FromWin32(point.Color);
String pointDescription = String.Format("({0}, {1}, {2}, {3}",
point.X, point.Y, point.Z, color.ToString());
(*(pointBuffer + numberOfPoints)).X = 0;
(*(pointBuffer + numberOfPoints)).Y = 0;
(*(pointBuffer + numberOfPoints)).Z = 0;
(*(pointBuffer + numberOfPoints)).Color = 0;
(*(pointBuffer + numberOfPoints)) = new CloudPoint(0, 0, 0, 0);
tr.Commit();
try
;// XYZ midpoint = (boundingBox.Min + boundingBox.Max) / 2.0;
catch (Exception ex)
message = ex.Message;
return Autodesk.Revit.UI.Result.Failed;
return Result.Succeeded;
1 REPLY 1
augusto.goncalves
in reply to: yscgrs
About the get BoundingBox, can you quick try Regenerate the document before? Changes on geometry do not take effect until the end of command, unless with a call to this method.
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Rail Community
