Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
is this code safe?
1 REPLY 1
phildebrandt
582 Views, 1 Reply
is this code safe?
if(selection.Elements.Size == 1)
                    System.Collections.IEnumerator es = selection.Elements.GetEnumerator();
                    es.MoveNext();
                    Type t = es.Current.GetType();
                    switch (t.FullName)
                        case "Autodesk.Revit.DB.ImportInstance":
                            TaskDialog.Show("test", "Revit file selected.");
                            break;
                        case "Autodesk.Revit.DB.Instance":
                            break;
                        case "Autodesk.Revit.DB.FamilyInstance":
                            TaskDialog.Show("test", "Revit family selected.");
                            break;
                        default:
                            TaskDialog.Show("test", "Default switch case.");
                            break;
I'm just wondering how safe the code above is to use? Namely, if this is used in a foreign country do the class names change?
1 REPLY 1
ollikat
in reply to: phildebrandt
I don't know about the safety but wouldn't it also work like this (C++):
"if (t == ImportInstance::typeId)"
(I'm not sure about C#...typeof(ImportInstance) might be the same thing...?)
Think that this might be more robust way of doing that.
Rail Community
