Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Is there a way to output the total (sum) length of each pipe size in a schedule?
1 REPLY 1
nur91m
738 Views, 1 Reply
First question  -  Is there a way to output the total (sum) length of each pipe size in a schedule with API?
Second question - How can I format a field? For example I want to set the length unit in meters not millimiters.
1 REPLY 1
jeremytammik
in reply to: nur91m
Dear nur91m,
1. http://thebuildingcoder.typepad.com/blog/2012/05/the-schedule-api-and-access-to-schedule-data.html
2. http://thebuildingcoder.typepad.com/blog/2013/04/whats-new-in-the-revit-2014-api.html
Unit Formatting and Parsing
The methods:
  • UnitFormatUtils.FormatValueToString()
  • UnitFormatUtils.TryParse()
provide the ability to format a value into a string based on formatting options and to parse a formatted string (including units) into a value if possible.
Unit Conversion
The new class UnitUtils contains methods to convert between unit types:
  • UnitUtils.Convert() – Converts a value from one unit type to another, such as square feet to square meters.
  • UnitUtils.ConvertFromInternalUnits() – Converts a value from Revit's internal unit type.
  • UnitUtils.ConvertToInternalUnits() – Converts a value to Revit's internal unit type.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Rail Community
