Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
In revit, how can I access XData stored in imported DWG
1 REPLY 1
457 Views, 1 Reply
First, I store XData in a DWG drawing. Second, I import the DWG  in Revit.
Now,I need to retrieve XData stored in the imported DWG programmingly.
Which revit API should I use? Anyone can help me,thanks.
1 REPLY 1
Dale.Bartlett
This is a good question and I shall be interested in the replies. Pre 2014 it was not even possible to access the 3D data in a Dwg. In that case I wrote the 3D coordinates out to XML to read into Revit. Not exactly what you asked, but may be an option if the XData is not directly accessible. Dale.
______________
Yes, I'm Satoshi.
Autodesk DevCon in Munich May 28-29th
Rail Community
