Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
how to use api to Mark model size
1 REPLY 1
sd1036770
284 Views, 1 Reply
Hello,i am new here,i want to ask a question
for example i have a hole in the wall , i want to use api to calculate the size of the hole and mark on the screen like diameter,can revit api do this?if it can,how to do that?
or not calculate,just read the attribute of the size and mark it on the screen
Thanks~~~~
1 REPLY 1
enonrick
in reply to: sd1036770
You can try to create dimension
ReferenceArray curveRefs;
DetailCurve newCurve;
double len;
Line boundLine;
len = Common.LinesLength(boundPt1.X, boundPt1.Y, boundPt2.X, boundPt2.Y);
boundLine = _document.Application.Create.NewLineBound(boundPt1, boundPt2);
newCurve = _document.Create.NewDetailCurve(curSelView, boundLine);
curveRefs = new ReferenceArray();
curveRefs.Append(newCurve.GeometryCurve.get_EndPointReference(0));
curveRefs.Append(newCurve.GeometryCurve.get_EndPointReference(1));
_document.Create.NewDimension(curSelView, boundLine, curveRefs);
You can apply the curve with your hole's diameter
Rail Community
