Recently we have been moving to using a shared parameter file that contains parameters for our Rooms. We have started integrating these parameters into our new projects. However, for older projects we were using project parameters for the same purpose. Now I would like to update some of these older projects so that they use the new shared parameters instead of the old project parameters. I have been able to swap out the values correctly on the actual elements in the project but I have not been able to 100% swap out the parameters inside of schedules.
I swap the parameters in the schedule by inserting the new parameter at the same index as the old, copying the properties from the old parameter to the new, then deleting the old parameter from the schedule. This all works fine except for that the group headers are lost when new parameter is inserted.
BEFORE
AFTER
This makes sense because this is the exact same thing that happens if I manually delete the old parameter and then add the new parameter using the user interface. However, I don't know how I could capture the old group header data and then recreate them using code. How could I accomplish this?
private void SwapParametersInSchedule(Document document, ElementId categoryId, ElementId existingParameterId, ElementId newParameterId) { FilteredElementCollector schedules = new FilteredElementCollector(document); schedules.OfClass(typeof(ViewSchedule)); foreach (ViewSchedule schedule in schedules.ToElements()) { if (schedule.Definition.CategoryId != categoryId) continue; ScheduleField oldField = null; foreach (ScheduleFieldId fieldId in schedule.Definition.GetFieldOrder()) { ScheduleField field = schedule.Definition.GetField(fieldId); if (field.ParameterId != existingParameterId) continue; oldField = field; } if (oldField != null) { ScheduleField newField = schedule.Definition.InsertField(oldField.FieldType, newParameterId, oldField.FieldIndex); newField.ColumnHeading = oldField.ColumnHeading; newField.GridColumnWidth = oldField.GridColumnWidth; if (oldField.CanTotal()) newField.HasTotals = oldField.HasTotals; newField.HeadingOrientation = oldField.HeadingOrientation; newField.HorizontalAlignment = oldField.HorizontalAlignment; newField.IsHidden = oldField.IsHidden; if (oldField.FieldType == ScheduleFieldType.Percentage) { newField.PercentageBy = oldField.PercentageBy; newField.PercentageOf = oldField.PercentageOf; } newField.SheetColumnWidth = oldField.SheetColumnWidth; if (oldField.CanTotalByAssemblyType()) newField.TotalByAssemblyType = oldField.TotalByAssemblyType; newField.SetFormatOptions(oldField.GetFormatOptions()); newField.SetStyle(oldField.GetStyle()); schedule.Definition.RemoveField(oldField.FieldId); } } }
As an alternative, through the UI, I know that you can easily change the parameter that a schedule field points to by selecting one of the cells and then on the ribbon changing the parameter from a drop drown (see image below). Is there a way to do this using the API?
