How to Revit 2016 api Create Dimension between Grid
on Revit 2014,my program ok,but on Revit 2016,it's give me a error,I search web along time,have not find the Reason
Main code
ReferenceArray refArray = new ReferenceArray();//分尺寸
foreach (ElementId e in eSet)
if (doc.GetElement(e).GetType() == typeof(Grid))
Grid gr = doc.GetElement(e) as Grid;
Curve cv = gr.Curve;
refArray.Append(cv.Reference);
if (!doc.IsFamilyDocument)
doc.Create.NewDimension(doc.ActiveView, line, refArray);//分尺寸
else
doc.FamilyCreate.NewDimension(doc.ActiveView, line, refArray);//分尺寸
Charles.Piro
how you create the "line" ?
PIRO Charles
Developer
PIRO CIE
Linkedin
The "line"'s start point is pick a point(snap on a Grid point),end point Calculation by start point,Increasing along the X axis.
 thinks.
jeremytammik
Dear cao2013,
Have you debugged your code?
If not, please do.
The answer is probably quite simple.
Nobody but you can debug your code without a full and really minimal reproducible case to examine:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
boostyourbim
In 2016, get the grid reference for dimensioning like this
Reference gridRef = null;
Options opt = new Options();
opt.ComputeReferences = true;
opt.IncludeNonVisibleObjects = true;
opt.View = doc.ActiveView;
foreach (GeometryObject obj in grid.get_Geometry(opt))
if (obj is Line)
Line line = obj as Line;
gridRef = line.Reference;
dnenovMXKU9
Great answer! Thanks a lot.
