Dear members,
How can I open a NWD file without using Naviswork Freedom or other Autocad-related software?
Is it possible to convert NWD file to a common file format like .CSV?
Thank you.
Dear Ericjoe,
You will have to be very lucky indeed to receive a knowledgeable answer to your Naviswork related question here, since this forum is dedicated to the Revit API.
Please try the other discussion forums that target Navisworks customisation directly:
http://forums.autodesk.com > search for "navisworks api"
http://forums.autodesk.com/t5/Navisworks-API/bd-p/600
You will probably have better luck there.
Best regards,
