Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to include exterior wall boundary polyline in exported DWG/DXF?
12 REPLIES 12
Message 1 of 13
1340 Views, 12 Replies
Using the API, I am exporting a DWG/DXF of a floor plan from Revit.  In the DWG/DFX, I need a polyline representing the outside of the exterior wall and a polyline representing the inside of the exterior wall. There are options to create polyline boundaries for each room during export, but I have not found a way to create polylines for the exterior wall.
How can I accomplish that?
12 REPLIES 12
Message 2 of 13
Hi All,
I am still looking for some way to do this.  If anyone has any ideas, I would really appreciate hearing them so I can try them out.
Thanks.
Message 3 of 13
augusto.goncalves
I made some testing and research on my side but, unfortunatly could not find an API for this. The DWGExportOption object has some other features, but not this specific one...
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Message 4 of 13
in reply to: augusto.goncalves
Hi Augusto,
Thank you for looking into it - though, that's not the answer I was wanting to hear.
What would I do to create an enhancement request to add that option?  I'm surprised others haven't requested that the floor boundaries for the inside and outside of the exterior wall be included (as a closed polyline) in the generated DWG/DXF.
-Ed
Message 5 of 13
jeremytammik
Dear Esilky,
I actually answered this very question just now in your subsequent thread
http://forums.autodesk.com/t5/revit-api/getting-floor-gross-area/m-p/5527432
In short, determine the bottom face of the floor slab in the Revit API and grab the geometric data for its outer boundary loop from there:
http://thebuildingcoder.typepad.com/blog/2008/10/slab-boundary.html
If you require this data in an AutoCAD element, you can use the AutoCAD.NET API to generate a polyline from it.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 6 of 13
in reply to: jeremytammik
Thanks Jeremy,
I'll look into these options for getting the area values.  For this specific question, I was looking for a way to include a closed polyline of the floor's exterior and interior boundary in the exported DWG/DXF.  I am trying to integrate to Revit in a similar way that we integrate to AutoCAD.  In AutoCAD, the user is required to manually polyline a drawing with the floor exterior and interior boundaries, and the room boundaries.  I was hoping we could eliminate this step when using Revit.  I don't want to require the user to do anything manually, or to require a step in AutoCAD.
Thank you.
-Ed
Message 7 of 13
jeremytammik
Dear Ed,
That definitely sounds achievable to me.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 8 of 13
Hi !
Is there any luck that you succesfully code it? It is possible to share it ?
Thank you !
Message 9 of 13
No, I have not been able to get the floor boundaries as polylines in the floor plan.  I've only been able to get room and area boundaries included.
Message 10 of 13
Hi Esilky,
You may be interested to think about how a convex hull implementation might help you achieve what you desire.  Check it out here:
https://en.wikipedia.org/wiki/Convex_hull
-Ken
Message 11 of 13
Moustafa_K
Just had a quick look and Realized it can be done via UI i didn't yet start on how via API
1st Create an Area Plan and make sure it is Gross building and not Rentable.
2nd make sure in Export Option to check Export Areas, rooms, Spaces ...ect as PolyLine
I think you can follow the same proceedure via API and then Roll back the Changes (do not commit transaction) to undo Creating Area Views.
Hope that Helps
Moustafa Khalil
Message 12 of 13
in reply to: Moustafa_K
Thank you for your anwsers ! We will try in an another way. And if my developpers find a workround i will let you know.
Jeremy
Message 13 of 13
Excuse my english I'm Algerian. If you export correctly your patterns ( of walls ) to dwg you can simply click on generate contours of patterns on Autocad by right click on it, that will generate your polyline. Peace.
Autodesk DevCon in Munich May 28-29th
Rail Community
