Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to Identify a Beam is Cellular through API?
3 REPLIES 3
sankar_g
355 Views, 3 Replies
Hi
   I am trying to Identify cellular beams from the selected elements through API. Any Ideas..
sangsen
3 REPLIES 3
mikako_harada
in reply to: sankar_g
Hi Sansen,
Not sure if I understand your question.  Do you have a Cellular beam family defined?  Or using somebody else and trying to get some property?  Maybe if you point to where you identify in UI using a sample family, maybe we can point to it.
Mikako Harada
Developer Technical Services
sankar_g
in reply to: mikako_harada
Hi..
  Thanks for your response.
  I am using Revit instalation families only. From Beam section details,  Can I able to Identify beam is Cellular or not?
Joe.Ye
Revit didn't expose the API to determine if a column, beam is a celluar section.
You can judge if it is culluar by analyzing the family instance's geometry data.
calling Element.Geometry() property to get its geometry data, and then get the bottom face (column) or the side face(beam). Then check if the face  contains arc edge or not.
Joe Ye
Contractor
Autodesk Developer Network
Rail Community
