How to get List & Hierarchy of Linked and sub-linked Revit files
impararia
Message 1 of 12
impararia
Hello
We're trying to get the list and hierarchy of all linked external files. Right now we tried the following code:
FilteredElementCollector collectorI = new FilteredElementCollector(DocChild);
IList<Element> elemsI = collectorI.OfCategory(BuiltInCategory.OST_RvtLinks).OfClass(typeof(RevitLinkInstance)).ToElements();
foreach (Element eI in elemsI)
    if (eI is RevitLinkInstance)
        RevitLinkInstance InstanceType = eI as RevitLinkInstance;
        RevitLinkType type = DocChild.GetElement(InstanceType.GetTypeId()) as RevitLinkType;
        TaskDialog.Show("Debug", "IsNestedLink=" + type.IsNestedLink.ToString() + " IsLinked=" + DocChild.IsLinked.ToString());
        if (!type.IsNestedLink)
            TaskDialog.Show("Debug", "Children=" + InstanceType.GetLinkDocument().PathName.ToString());
We succeded to get the list of all linked files but there's no hierarchy. We don't know which file is a chieldren of which parent.
This is the Link structure we're trying to get:
Replies (11)
Message 2 of 12
Revitalizer
you need to call the function recursively,
making InstanceType.GetLinkDocument() your new DocChild.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 3 of 12
impararia
Hi
Thank you for the replay. We tested the method and this is the result:
Document tmp= docchild.getlink();
Result: tmp= null
We tried another approach where we open in background the Sub-Assembly in order to get it's linked files using Open/Activate but the system said it's already open. We tried to find the API for "Read Only" mode but no solution.
We tried anothr approach where we unload all linked documents; the getlink doesn't find the lined documents.
Any advise is helpfull
Regards
Message 4 of 12
jeremytammik
Dear Impararia,
I agree with Rudi: you need to call the method recursively.
It is not at all clear to me what you have and have not tried so far, and in what way it is failing.
Maybe you need to submit a minimal reproducible case to clarify?
http://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 5 of 12
impararia
Hi Jeremy
This is the detail to reproduce the case:
1- We have a main Revit Model called Assembly16122015-1.rvt. it contains sub-assemblies (external linked files ) and those ones contain other sub-assemblies (external linked files). So we have 3 level external files links.
Our purpose is to read the "links", "documents paths" and "document names" through all external links levels.
2- Behaviour versus expectation: We expected to get links, names and hierarchy of all documents. The problem is that, we can't get the names of the documents linked as attachement to the level2 linked document.
Level0:Assembly16122015-1.rvt.
    Level1: Linked document1
        Level2: Linked document12
            Level3: Linked document121
            Level3: Linked document122
Level1:Linked document2
we get the names of document 121 & 122 but we are not able to know that they're the children of document12
3- Revit Sample Models: All files are attached here. Extract all; open the Assembly16122015-1.rvt then load the external links as attachement to the other provided files.
4- Sample Code:
public class SaveCmd : IExternalCommand
       public struct test
           public int       Level   { get; set; }
           public Document  Doc     { get; set; }
      // The main Execute method (inherited from IExternalCommand) must be public
     public Autodesk.Revit.UI.Result Execute(ExternalCommandData revit,
          ref string message, ElementSet elements)
          UIDocument uidoc = revit.Application.ActiveUIDocument;
          Document Doc = null;
          try
              Doc = uidoc.Document;
          catch (SystemException e)
              TaskDialog.Show("Warning", "No Actif Document");
              return Autodesk.Revit.UI.Result.Failed;
          if (NumberLink(Doc) != 0)
              List<test> Listtest = new List<test>();
              test new_test = new test();
              new_test.Level = 0;
              new_test.Doc = Doc;
              Listtest.Add(new_test);
              int i = 0;
              int AddLine = 0;
              do
TaskDialog.Show("Warning", "i=" + i + " Pathname=" + Listtest[i].Doc.PathName);
                  AddLine = 0;
                  if (NumberLink(Listtest[i].Doc) != 0)
                      FilteredElementCollector collectorI = new FilteredElementCollector(Listtest[i].Doc);
                              RevitLinkType type = Listtest[i].Doc.GetElement(InstanceType.GetTypeId()) as RevitLinkType;
                                  new_test.Level = Listtest[i].Level + 1;
                                  new_test.Doc = InstanceType.GetLinkDocument();
                                  AddLine++;
TaskDialog.Show("Warning", "Insert index=" + (i + AddLine) + " name=" + InstanceType.GetLinkDocument().PathName);
                                  Listtest.Insert(i + AddLine, new_test);
                  i++;
              while (i < Listtest.Count);
              for (i = 0; i < Listtest.Count; i++)
                  TaskDialog.Show("Debug", "Level = " + Listtest[i].Level + " Pathmane =" + Listtest[i].Doc.PathName);
          return Autodesk.Revit.UI.Result.Succeeded;
      public static int NumberLink(Document Doc)
          int nbLink = 0;
          FilteredElementCollector links = new FilteredElementCollector(Doc).OfCategory(BuiltInCategory.OST_RvtLinks);
          foreach (Element e in links)
              if (e is RevitLinkType)
                  nbLink++;
          return (nbLink);
5- Step-By-Step:
- Open the  Assembly16122015-1.rvt in Revit
- Reload all links form the provided files. You'll see that it's 3 level linked document
- Select the Assembly16122015-1.rvt  and run the code in VB
- The code will continue to show all info captured while reading all links starting from Assembly16122015-1.rvt. When it reaches the Level2 sub-assembly we are not able to see that it has children and what are their names.
Hope this will help understanding the problem.
Thank you for your help
Message 6 of 12
impararia
Please donwload these files because I can't upload more than 3 files at a time.
Message 7 of 12
impararia
Message 8 of 12
impararia
Message 9 of 12
Dale.Bartlett
This looks like what you want:
http://adndevblog.typepad.com/aec/2015/12/reading-revit-links-hierarchy.html
Merry Xmas, Dale
______________
Yes, I'm Satoshi.
Message 10 of 12
jeremytammik
A handy way to share multiple files is to either zip them up into one single archive file or place them somewhere publicly accessible, e.g. in a public dropbox folder.
Thank you!
Jeremy Tammik
The Building Coder
Message 11 of 12
jeremytammik
As also noted by Augusto on StackOverflow...
http://stackoverflow.com/questions/34336797/how-to-get-list-hierarchy-of-linked-and-sub-linked-revit...
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 12 of 12
impararia
Thank you for the replay. The suggested link solved the problem.
Jeremy: I wasn't able to attach a .zip more than 5MB at a time. We'll use Dropbox in the future.
Regards
