Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to create a Revit palette/window to display the results of calculations
7 REPLIES 7
Message 1 of 8
zwoodruff
826 Views, 7 Replies
I am developing an application that performs some calculations on a revit model and then displays the results to the user. Is there a way to create a window/palette like the properties or project browser windows where the results of the calculations can be displayed and updated as the model changes?
Thanks for the help.
7 REPLIES 7
Message 2 of 8
jeremytammik
in reply to: zwoodruff
Dear Zwoodruff,
Nope, not really. The Revit external application frmaework enables you to add certain widgets to the Revit ribbon, no more. For what you describe, you would have to rool your own, e.g. using the .NET framework.
Best regards,
Jeremy
Jeremy Tammik
Autodesk Developer Network -- http://www.autodesk.com/joinadn
The Building Coder -- http://thebuildingcoder.typepad.com
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 3 of 8
zwoodruff
in reply to: jeremytammik
Thank you for your help. Do you have an example of how I might do something similar with the .NET framework? The point of the add-in is to provide the calculations in an "in your face" way throughout the design process so that the user will be more conscious of how changes to the model effect the results.
Is there a way to develop an external program that can access properties, geometry, and material data from Revit continuously (or something like five minute intervals), and then provide the results of the calculations?
Thanks.
Message 4 of 8
jeremytammik
Dear Zwoodruff,
Here is a really old example:
http://thebuildingcoder.typepad.com/blog/2009/10/modeless-pressure-drop-tool.html
This is a modeless form which reamins displayed as long as the command is active, blocking further Revit activity.
You would probably want something completely modeless.
For that please look at the ModelessDialog ModelessForm_ExternalEvent and ModelessForm_IdlingEvent SDK samples:
http://thebuildingcoder.typepad.com/blog/2012/03/new-revit-2013-sdk-samples.html#1
Best regards,
Jeremy
Jeremy Tammik
Jeremy Tammik
The Building Coder
Message 5 of 8
zwoodruff
Thanks again for the help, that looks like the best way to implement this. I tried to load the samples and am getting the error "Object reference not set to an instance of an object." when I try to run them. Do you know what the problem might be? I didn't make any changes to the sample program I simply compliled it and added the .addin reference to the .dll file.
Best regards,
Zack
Message 6 of 8
jeremytammik
hi zack.
oh, your name is zack?
zwoodruff could be interpreted as germen slang for 'add two', 'zwoo druff', 'zwei drauf'  🙂
which was what i imagined was the origin for your moniker  🙂
nope, no idea what is going on.
grab your debugger, find out, fix it, and let me know, please!
cheers
jeremy
Jeremy Tammik
The Building Coder
Message 7 of 8
zwoodruff
Hi Jeremy,
I tried debugging and it gave the same issue, and attempted running it with the Add-in manager and RvtSample and neither were working. After fussing around I simply started over from scratch and something worked. One of those programming problems that seems to miraculously fix itself.
Thanks for the help and the interesting sidetrack into some german slang!
Zack
Message 8 of 8
jeremytammik
thank for letting me know, and sorry for the hassle you had to go through...
Jeremy Tammik
The Building Coder
Rail Community
