Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to assign new Command with Shortcut Key through Revit API
2 REPLIES 2
458 Views, 2 Replies
Hi All,
I want to create a new command with my own Shortcut key in Revit 2015 through API.
I able to provide only shortcutkey for existing command, but in my scenario, i want to create a  new command in that list.
I unable to find, where exactly 'KeyboardShortcuts.xml' or  KeyboardShortcuts.txt will be available in our systems.
Please help me.
2 REPLIES 2
Aaron.Lu
dear, I'm not sure where they are located, but you can type "KS" in the project editor, and find the command in the popped up dialog to assign shortcuts to it.
Aaron Lu
Developer Technical Services
Autodesk Developer Network
jeremytammik
Dear Mallikarjuna,
Here are two related discussions on The Building Coder:
http://thebuildingcoder.typepad.com/blog/2015/02/keyboard-shortcuts-and-other-news.html#5
http://thebuildingcoder.typepad.com/blog/2012/06/replacing-built-in-commands-and-their-ids.html
The most important hints for you are probably to be found in the attached comments.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Rail Community
