Hello everyone
I am developing a Revit addin using Vb.net 2012 I made a class to create a project (rvt) based on a template (rte). Now I need to execute or call my class from a button on my form. How I execute the class? someone has an example ?. this is my code.
In The Form1
Private Sub Btt_Crear_Click(sender As Object, e As EventArgs) Handles Btt_Crear.Click
Dim plt As New PLT_ARQ
plt.Execute()
End Sub
in the Class PLT_ARQ
Imports System
Imports System.IO
Imports System.Diagnostics
Imports System.Collections.Generic
Imports Autodesk.Revit.ApplicationServices
Imports Autodesk.Revit.Attributes
Imports Autodesk.Revit.DB
Imports Autodesk.Revit.UI
Imports Autodesk.Revit.UI.Selection
<Transaction(TransactionMode.Manual)>
Public Class PLT_ARQ
Implements IExternalCommand
Public Function Execute(
ByVal commandData As ExternalCommandData,
ByRef message As String,
ByVal elements As ElementSet) _
As Result Implements IExternalCommand.Execute
Dim uiapp As UIApplication = commandData.Application
Dim uidoc As UIDocument = uiapp.ActiveUIDocument
Dim app As Application = uiapp.Application
If form.SaveFileDialog1.ShowDialog() = Windows.Forms.DialogResult.OK Then
Dim CurrentPath As String = "C:\"
Dim TemplateFile As String = "model.rte"
Dim templateFullPath As String = System.IO.Path.Combine(CurrentPath, TemplateFile)
Dim newDoc As Document = app.NewProjectDocument(templateFullPath)
Dim newFileName As String = System.IO.Path.Combine(form.SaveFileDialog1.InitialDirectory, form.SaveFileDialog1.FileName)
newDoc.SaveAs(newFileName)
newDoc.Close()
uiapp.OpenAndActivateDocument(newFileName)
Return Result.Succeeded
End Function
End Class
Hi marcosmateo!
From your original post it's unclear if you created a class that extends IExternalApplication. This is a class that is automatically/manually loaded when Revit starts up. Also in this class you define "RibbonTab"s, "RibbonPanel"s, "RibbonButton"s and assign IExternalCommand classes (like the one you created) to those buttons. A simple example can be shown in the sticky thread in Revit API subforum (MyFirstRevitPlugin).
