Afternoon all,
One of our techs approached me a couple days ago about creating a command that would turn off the level heads in specific views. Level lines were to remain, but heads were to be shut off. This will facilitate in creating "pretty drawings"(see attached file) without the effort of clicking off individual level heads in each view,which can sometimes be up to 10 additional clicks in multiple views. OVer the life of the project this coukd add up to a few hundred clicks that could be saved by one per view.
Here's the problem: I've found the BuiltinParameter.Datum_Bubble_End_1 and 2, which allow me to globally turn off and on ALL the levelheads, but this doesn't allow me to do it per view. So I would be able to turn them all off and then in certain views I'd have to go back and turn them back on. I've found the visibility graphics controls which allow me to work perview, but since the lines are to remain I can't use that.
Any ideas?
Solved by R.van.den.Bor. Go to Solution.
You can't. I believe this question is allready on the wishlist (or should be). The only thing you can do is to change the bubble heads style based. But the user can overrule this manually and you don't have any API grip on it.
