Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
[HELP] About committing transaction in Thread...
2 REPLIES 2
979 Views, 2 Replies
I'm developing an add-in on Revit2013, it involves using a thread to do some calculation and commit the changes back to the .rvt. Now the problem occurs:
When I use transaction in the main thread, namely the IExternalCommand one, it is totally ok; yet if I put the code inside a self created thread, the whole Revit would abort and exit !
Here's the code i put in a thread:
Thread t = new Thread(delegate()
   try
       using (Transaction tras = new Transaction(commandData.Application.ActiveUIDocument.Document,"test"))
        tras.Start();
        tras.Commit();
   catch (Exception e)
      MessageBox.Show(e.Message);
t.Start();
even the catch could not get the exception, the Revit just exit without exception report.
I really have no idea why Revit doesnt let me commit transaction inside other thread ( I have trace the error, it occur before the tras.Commit ). Anyone have any idea? Thanks ahead.
Tags (2)
2 REPLIES 2
ollikat
I'm sorry to tell you that the Revit API doesn't support calls from other threads. It's a simple as that 🙂
At least here you can find some more information:
http://thebuildingcoder.typepad.com/blog/2011/06/no-multithreading-in-revit.html
saikat
in reply to: ollikat
Yes, your findings are correct.
The following post might also be helpful:
http://adndevblog.typepad.com/aec/2012/06/multi-threading-with-revit.html?asset_id=6a0167607c2431970...
cheers
Saikat
Saikat Bhattacharya
Senior Manager - Technology Consulting
Autodesk DevCon in Munich May 28-29th
Rail Community
