Have code that works in VB.net 2012 trying to learn C# and convert code. Last piece of puzzle.
"Parameter .Definition.Name" is null.
ele.Name = L4x3 1/2x5/16 . so that 's ok
Leg Guage is a parmater I created which is part of the angle.
LegGa = 4.00 which is ok.
using C# 2012 and Revit 2015
public void ChangeAngleParam(Element ele)
ParameterSet @Anonymous = ele.Parameters;
Autodesk.Revit.DB.Parameter Parameter = default(Autodesk.Revit.DB.Parameter);
double ParamElem = 0;
AngleData(ele);
if (ele.Name.StartsWith("L")) {
foreach ( Parameter para in @params)
if ((Parameter .Definition.Name == "Leg Guage"))
ParamElem = (Convert.ToDouble(LegGa) / 12);
Parameter.Set(ParamElem);
Any advise would be appreciated.
Bob V
Solved by sanjaymann. Go to Solution.
Replace
with
if ((para.Definition.Name == "Leg Guage"))
Thanks & Regards
