Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Get ImportInstance dwg name
3 REPLIES 3
Dale.Bartlett
875 Views, 3 Replies
I am missing something obvious. I want to return the name of an Imported (not linked) DWG. The following is just not doing it for me...
foreach (ImportInstance ii in new FilteredElementCollector(pDoc)
.OfClass(typeof(ImportInstance))
.Cast<ImportInstance>()
.Where(i => i.IsLinked == false))
ElementId Id = ii.Id;
string name = ii.Name;
string tname = ii.GetType().Name;
______________
Yes, I'm Satoshi.
3 REPLIES 3
Have you tried the
ii.Category.Name property?
That returns the name in my application...
The day is made when you learn one new thing...
Many thanks, Dale
______________
Yes, I'm Satoshi.
rodrigohbm
in reply to: Dale.Bartlett
Hello
There is way to get the path file
example:
c:\structural\sheet\102-floor 1 plant.dwg
and change path
c:\mep\structural\sheet\102-floor 1 plant.dwg
regards
Autodesk DevCon in Munich May 28-29th
Rail Community
