Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
get corner points of the curtain panel based on (nesting) concept mass family
3 REPLIES 3
Ning_Zhou
255 Views, 3 Replies
similar to the comment by Charlie Portelli in the following link:
http://thebuildingcoder.typepad.com/blog/2010/05/curtain-wall-geometry.html
obviously it's different from the normal curtain wall or curtain system approach, what is the proper procedure? thanks in advance.
3 REPLIES 3
jeremytammik
in reply to: Ning_Zhou
Dear Ning,
Thank you for your query.
I am checking with the development team and will let you know what I find out.
Meanwhile, could you provide a minimal reproducible case to demonstrate the issue?
http://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Thank you!
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Ning_Zhou
in reply to: jeremytammik
thanks Jeremy.
i uploaded the file here for your reference, just the simplified RVT, how to get 4 points of the glass panel? didn't have any code yet as no idea how to do it.
Cheers,
Ning
jeremytammik
Dear Ning,
Thank you for the sample file. I passed it on and will let you know as soon as I hear anything back.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Rail Community
