From the API, can I set the family category having started from a generic model template?
I recall being told it might be possible in 2014 (maybe I've overlooked and it's possible in earlier versions).
At the moment I ship various templates with categories preset.
Thanks in advance,
Jon
I enquired with my colleagues in engineering and they mentioned that this is possible in Revit 2014:
This was enabled in 2014 (from what’s new):
Family category
The property
can now be set. This allows the category of an family being edited to be changed.
Hope this helps.
Best Regards,
Gopinath Taget
Hi Gopinath,
Thanks for the reply. I can see this property can now be set, but what I can't see is how to construct a category object to assign.
Can you please advise (sorry for the delay in responding, I didn't use to many new categories since posting but looks like I will soon).
Jon
Have you looked at this blog post already: http://thebuildingcoder.typepad.com/blog/2012/04/adding-a-category-to-a-shared-parameter-binding.htm...
It talks about creating a new category and adding it to a new category set.
Cheers
Gopinath
Thanks, I hadn't seen that post.
I just tested and something like this seems to do what I need.
famDoc.OwnerFamily.FamilyCategory = famDoc.Settings.Categories.get_Item(BuiltInCategory.OST_PlumbingFixtures);
This is great news. Appreciate your help.
