I have simple code where I want to create FilledRegion. Whatever I do I get back: Boundaries are self-intersecting.
Here's my code:
IList<RDB.CurveLoop> boundaries = new List<RDB.CurveLoop>(); RDB.CurveLoop curve = CreateCurve(doc, new RDB.XYZ(0, 0, 0), new RDB.XYZ(0, 10, 0)); boundaries.Add(curve); RDB.CurveLoop curve2 = CreateCurve(doc, new RDB.XYZ(0, 10, 0), new RDB.XYZ(10, 10, 0)); boundaries.Add(curve2); RDB.CurveLoop curve3 = CreateCurve(doc, new RDB.XYZ(10, 10, 0), new RDB.XYZ(0, 0, 0)); boundaries.Add(curve3); CreateFilledRegion(doc, boundaries);
And here are two external functions:
private RDB.CurveLoop CreateCurve(RDB.Document doc, RDB.XYZ start, RDB.XYZ end) { RDB.Line line = doc.Application.Create.NewLine(start, end, true); RDB.CurveLoop curve = new RDB.CurveLoop(); curve.Append(line); XLIB.Geometry.CreateDetailLine(doc, start, end); return curve; } private void CreateFilledRegion(RDB.Document doc, IList<RDB.CurveLoop> boundaries) { RDB.Element t = XLIB.Selection.GetTypes(doc, typeof(RDB.FilledRegionType)).FirstOrDefault(); RDB.FilledRegion.Create(doc, t.Id, doc.ActiveView.Id, boundaries); }
Any thaugts?
Cheers,
Ivo
this is my working code snippet:
newCurveLoop = new List<CurveLoop>(); curveLoop = new CurveLoop(); for (int i = 0; i < LineCount; i++) {
.......... if ((LINE_TYPE)lineType == LINE_TYPE.LINEAR) curveLoop.Append(_document.Application.Create.NewLine(new XYZ(x1, y1, 0), new XYZ(x2, y2, 0), true)); else if ((LINE_TYPE)lineType == LINE_TYPE.ARC) curveLoop.Append(_document.Application.Create.NewArc(new XYZ(x1, y1, 0), radius, startRadian, endRadian, new XYZ(1, 0, 0), new XYZ(0, 1, 0))); } newCurveLoop.Add(curveLoop); FilledRegion.Create(_document, materialId, view.Id, newCurveLoop);
I'm just wondering, why are you recreated curveloop in each CreateCurve funtion,link this
just try it.
