I would like to overwrite a familySymbol available in the document when document opened event. The familySymbol is not available in the family text file (i.e) familySymbol is available only in document.
I tried LoadFamilySymbol() method with IFamilyLoadOptions arguments, it returns false and familySymbol as null. I dont want to create the symbol in family text file and i need only to update the familysymbol available in the document.
Could anyone help me to solve this issue.
sangsen
Solved by Lucavox. Go to Solution.
If you're trying to overwrite a FamilySymbol you could just find the one you're trying to chanage, start a Transaction, and then edit the parameters. No reason to reload the family at all, unless it's a different version. If you need to make a new Type of that family, you can just Duplicate the first FamilySymbol and then change the parameters.
This is a short code to Load a family in the document knowing the path and the type name you need:
string path = @"c:\familyfile.rfa"; string name = "Type name"; //You need to set the path and type name correctly Transaction t = new Transaction(Document, "load_my_symbol"); t.Start(); Document.LoadFamilySymbol(path, name); t.Commit();
I don't understand if you need to replace instances within the project. But if you need to use FamilyLoadoptions the code below could be helpful:
- First build the class
public class familyloadoptions : IFamilyLoadOptions { #region IFamilyLoadOptions Members public bool OnFamilyFound(bool familyInUse, out bool overwriteParameterValues) { if( !familyInUse ) { overwriteParameterValues = true; return true; } else { overwriteParameterValues = true; return true; } } public bool OnSharedFamilyFound(Family sharedFamily, bool familyInUse, out FamilySource source, out bool overwriteParameterValues) { if (!familyInUse) { source = FamilySource.Family; overwriteParameterValues = true; return true; } else { source = FamilySource.Family; overwriteParameterValues = true; return true; } } #endregion }
Here the code of the command:
string path = @"c:\familyfile.rfa"; string name = "Type name"; Transaction t = new Transaction(Document, "load_my_symbol"); t.Start(); FamilySymbol symb; Document.LoadFamilySymbol(path, name, new familyloadoptions(), out symb); t.Commit();
Kind regards,
Luca Vocella
