Revit API
Valued Contributor
GeomGym
Message 1 of 3 (253 Views)
FamillyParameter Structural Material Type
253 Views, 2 Replies
11-16-2012 04:47 AM
Hi All,
I'm creating some structural framing families using the API.
I want to be able to set existing family parameters such as "Structural Material Type" to Steel or Concrete etc.
But I don't seem to be able to identify the built in parameter id (and iterating through existing I can see it).
Can someone please adivse?
Jon
New Member
sweetfa2
Message 2 of 3 (232 Views)
Re: FamillyParameter Structural Material Type
11-26-2012 12:10 AM in reply to: GeomGym
Try calling the following code passing your instance that you want the parameter ids for.
The ID should be the second value on a line.
private void DisplayParameters(Element instance)
string message = "";
foreach (Parameter p in instance.Parameters)
message += string.Format("{0}:{4} [{1}-{2}] [{3}]\n", p.Definition.Name, p.StorageType.ToString(), p.HasValue, p.StorageType == StorageType.String ? p.ToString() : p.AsValueString(), p.Id);
TaskDialog.Show("Parameters", message);
ADN Support Specialist
Joe.Ye
Message 3 of 3 (157 Views)
01-16-2013 07:25 AM in reply to: GeomGym
Revit lookup can help to get the built-in parameter member name if you know the parameter name.
After click the "Parameters" property node in the RevitLookup, you can see the button named "Built-in Enums Map..." button. Click this button a dialog shows. Click the Value column to sort the parameter name. Then you can easily found the parameter that you already know its name string. In the right column  is the corresponding built-in member.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
