Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Failed to initialize the add-in...
2 REPLIES 2
stcw
2914 Views, 2 Replies
I'm new here,
I've installed Revit 2012 and wrote an add-in program,
the program can be compiled and add-in tab appeared in Revit,
but could anyone tell me how to solve this problem...
thanks a lot...
2 REPLIES 2
ollikat
in reply to: stcw
In the addin file, you must give the exact name of the class (including possible name space(s)), which represents your external command. Such a class must inherit IExternalCommand Interface. I also believe that the name of the class is case sensitive so check your spelling.
stcw
in reply to: ollikat
I've solved the problem, thanks a lot!
Autodesk DevCon in Munich May 28-29th
Rail Community
