Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Export DWG Help!
0 REPLIES 0
Message 1 of 1
naroura
320 Views, 0 Replies
Export DWG Help!
When I export a Sheet in DWG format the dwg file doesn't include the titleblock !
I have to export it twice to get the titleclock included !!!!
here is  the simple code I'm using with RST 2014:
public static bool ExportDWG(Autodesk.Revit.DB.Document document, View view, String Filename)
     bool exported = false;
     IList<string> setupNames = BaseExportOptions.GetPredefinedSetupNames(document);
if (setupNames.Count > 0)
// Get the export options for the first predefined setup
DWGExportOptions dwgOptions = DWGExportOptions.GetPredefinedOptions(document, setupNames[0]);
dwgOptions.FileVersion = ACADVersion.R2010;
dwgOptions.MergedViews = true;
dwgOptions.TargetUnit = ExportUnit.Meter;
dwgOptions.SharedCoords = true;
ICollection<ElementId> views = new List<ElementId>();
views.Add(view.Id);
exported = document.Export(Path.GetDirectoryName(document.PathName), Filename, views, dwgOptions);
return exported;
Any idea !
0 REPLIES 0
Rail Community
