Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
ERROR[28000]
2 REPLIES 2
623 Views, 2 Replies
ERROR[28000]
I tried to extract my project to connected SQL server.  I set my account as a admin at that SQL server.
However, it gave me an error like follow.
System.Data.OdbcException (0x80131937(: Error [28000] [Microsoft][ODBC SQL Server Driver][SQL Server]Login Failed for user ". the user is not associated with a trusted SQL Server connection.
What's the matter ans what's the solution?
Thank you for your answer in advance.
JINHOON LEE
2 REPLIES 2
ollikat
Have you checked MSDN etc. for the solution? It's very unlikely to get solution from here because your question is not related to Revit API at all.
Check this out, if it's any help
http://support.microsoft.com/kb/889615
in reply to: ollikat
Thank you.
It's definitely help me.
Because it's my first time to play with SQL DB, i have no idea.
Rail Community
