Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Easy Programming Exercise
3 REPLIES 3
Jazzster11
1111 Views, 3 Replies
Well, easy for someone other than me.  I am completely new to the Revit API and would like to create a script that deletes all of the views and sheets from a file.  Any suggestions?
Thanks.
- Alex
3 REPLIES 3
in reply to: Jazzster11
I'm learning the API so I figured I would take a crack at it.
I don't know your experience level with programming in general or even what language your using but the code below worked for me.  If it's over your head, I also attached the finished product.  To use the addin, place the addin in your Revit 2011 Addin folder (see below) and the Deleter.dll at C:\  Then next time your in Revit you will have this command available under the 'Addins' ribbon tab then under 'External Commands'
 Addin Locations:
XP - C:\Documents and Settings\All Users\Application Data\Autodesk\Revit\Addins\2011
Vista/7 - C:\ProgramData\Autodesk\Revit\Addins\2011
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using System.Collections;
namespace Deleter
    [Autodesk.Revit.Attributes.Regeneration(Autodesk.Revit.Attributes.RegenerationOption.Manual)]
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Automatic)]
    public class SheetsAndViews : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            // Warn the user about deleting all views and sheets
            TaskDialogResult result = TaskDialog.Show("Delete All?", "This command will delete all sheets and views in the current project. \r\n\r\nAre you sure you want to continue?",
                TaskDialogCommonButtons.Yes | TaskDialogCommonButtons.No, TaskDialogResult.No);
            //End the command if no was clicked
             if(result == TaskDialogResult.No)
                 return Result.Succeeded;
            // Get the active UIDoc
            UIDocument uiDoc = commandData.Application.ActiveUIDocument;
            try
                DeleteSheetsAndViews(uiDoc);
                TaskDialog.Show("Success", "All views deleted successfully.");
            catch (Exception Ex)
                TaskDialog.Show("Error", "An error occurred.\r\n\r\n" + Ex.Message);
                return Result.Failed;
        private void DeleteSheetsAndViews(UIDocument uiDoc)
            // Used to store the ElementIds to delete
            ArrayList list = new ArrayList();
            // Get all of the Views in the current drawing
            FilteredElementCollector collector = new FilteredElementCollector(uiDoc.Document);
            FilteredElementIterator iterator = collector.OfClass(typeof(View)).GetElementIterator();
            iterator.Reset();
            // Iterate all of the views and collect their ElementIds
            while (iterator.MoveNext())
                View v = iterator.Current as View;
                if (v.ViewName != uiDoc.Document.ActiveView.ViewName)
                    list.Add(v.Id);
            // Delete all of the collected ids
            foreach (ElementId id in list)
                uiDoc.Document.Delete(id);
Jazzster11
Thank you so much; I had pretty much given up on figuring this out.
I'll give it a shot.
- Alex
Sferra, I like the warning box at the beginning. The formatting on it is straight forward, and simple enough that users will actually read it. Thanks for sharing.
Autodesk DevCon in Munich May 28-29th
Rail Community
