Well, easy for someone other than me. I am completely new to the Revit API and would like to create a script that deletes all of the views and sheets from a file. Any suggestions?
Thanks.
- Alex
I'm learning the API so I figured I would take a crack at it.
I don't know your experience level with programming in general or even what language your using but the code below worked for me. If it's over your head, I also attached the finished product. To use the addin, place the addin in your Revit 2011 Addin folder (see below) and the Deleter.dll at C:\ Then next time your in Revit you will have this command available under the 'Addins' ribbon tab then under 'External Commands'
Addin Locations:
XP - C:\Documents and Settings\All Users\Application Data\Autodesk\Revit\Addins\2011
Vista/7 - C:\ProgramData\Autodesk\Revit\Addins\2011
using System; using System.Collections.Generic; using System.Linq; using System.Text; using Autodesk.Revit.UI; using Autodesk.Revit.DB; using System.Collections; namespace Deleter { [Autodesk.Revit.Attributes.Regeneration(Autodesk.Revit.Attributes.RegenerationOption.Manual)] [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Automatic)] public class SheetsAndViews : IExternalCommand { public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements) { // Warn the user about deleting all views and sheets TaskDialogResult result = TaskDialog.Show("Delete All?", "This command will delete all sheets and views in the current project. \r\n\r\nAre you sure you want to continue?", TaskDialogCommonButtons.Yes | TaskDialogCommonButtons.No, TaskDialogResult.No); //End the command if no was clicked if(result == TaskDialogResult.No) { return Result.Succeeded; } // Get the active UIDoc UIDocument uiDoc = commandData.Application.ActiveUIDocument; try { DeleteSheetsAndViews(uiDoc); TaskDialog.Show("Success", "All views deleted successfully."); } catch (Exception Ex) { TaskDialog.Show("Error", "An error occurred.\r\n\r\n" + Ex.Message); return Result.Failed; } return Result.Succeeded; } private void DeleteSheetsAndViews(UIDocument uiDoc) { // Used to store the ElementIds to delete ArrayList list = new ArrayList(); // Get all of the Views in the current drawing FilteredElementCollector collector = new FilteredElementCollector(uiDoc.Document); FilteredElementIterator iterator = collector.OfClass(typeof(View)).GetElementIterator(); iterator.Reset(); // Iterate all of the views and collect their ElementIds while (iterator.MoveNext()) { View v = iterator.Current as View; if (v.ViewName != uiDoc.Document.ActiveView.ViewName) { list.Add(v.Id); } } // Delete all of the collected ids foreach (ElementId id in list) { uiDoc.Document.Delete(id); } } } }
Thank you so much; I had pretty much given up on figuring this out.
I'll give it a shot.
- Alex
Sferra, I like the warning box at the beginning. The formatting on it is straight forward, and simple enough that users will actually read it. Thanks for sharing.
