Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Drawing base units
4 REPLIES 4
650 Views, 4 Replies
Drawing base units
How can I find the whether the drawing is a Metric or Imperial drawing. And
if metric, whether the base units are set to Millimeters or something else.
John
4 REPLIES 4
I don't think this question is meaningful for Revit. Internally Revit stores
all coordinates in universal units (feet) regardless of geography or
localization considerations. Revit just displays dimension according to user
preferences. Thus the same rvt file may show some dimensions as imperial and
others as metric. This also allows loading imperial families into project
that is dimensioned in metric or the other way around. It works differently
from Autocad.
"jwj" wrote in message
news:5145805@discussion.autodesk.com...
John
Interesting! Thanks for the tip. That will save me heaps of digging
around!
"Leonid Raiz" wrote in message
news:5145880@discussion.autodesk.com...
from Autocad.
John
Actually, I believe it is a meaningfull question. How can we find out what
the CURRENT unit type is? if I want to prompt the user to enter a window
size, is he/she going to do it in metric millimeter or foot/inch entry?
This is important...the base level...what will Revit understand is
feet...but what is the user entering?
John
from Autocad.
John
The approach to user input in Revit is analogous to the approach to output.
User may type a specific unit designation i.e. 2", 5m, or 1200mm. User may
even type a formula containing a mixture of units like = 32' 6" + 3m. If
however user does not type the unit indicator then input is interpreted
according to a current setting in Units dialog. User however may change this
setting during a session. This is just the outline of the approach. There
are some special cases for when dealing with very small items like pen
thicknesses but you get the general idea. You may play with Revit
interactively and discover for yourself.
news:5146289@discussion.autodesk.com...
John
from Autocad.
John
Autodesk DevCon in Munich May 28-29th
Rail Community
