I am a student studying Interior Designing. We are the begginers in Revit this semester.
After hours of download, I get the following message
Some products failed to install...
1. Autodesk Revit 2016
2. Autodesk Revit Content libraries 2016
3. Autodesk BIM 360 Add in for Revit 2016
4. Autodesk Material Library 2016 - Medium Image Library
5. Autodesk Application Manager
Finally the download fails. Can anyone please help me with the installaton process and rectify the issue why this is happening.
I have Windows 8 and over 900GB space in my computer.
Please reply.
Thanks.
Zarina
Solved by rosalesduquej. Go to Solution.
Hi @zarin1985 Welcome to Autodesk Community!
Try the solutions in this article: Some Products Failed to Install, Result 1603. Or you can re-download the program from our Virtual Agent (click on Download Links, choose product and version). Make sure you disable your firewall and anti-virus programs. Then try the installation again.
Hi Zarin,
Most likely you will not get an answer from this forum since
Revit API forum is for API (Application Programming Interface) questions.
For non-API questions, please choose other forums that is more appropriate. For example,
Installation and licensing:
http://forums.autodesk.com/t5/installation-licensi
Revit Architecture (including common platform product usage questions):
http://forums.autodesk.com/t5/revit-architecture/b
Revit Structure:
http://forums.autodesk.com/t5/revit-structure/bd-p
Revit MEP:
http://forums.autodesk.com/t5/revit-mep/bd-p/188
Thank you for understanding.
Not sure you guys are getting it. Download of files just doesn't work. Download manager doesn't work. How about starting there, fixing that.
