Hi, i am new at the Revit API and i am following the DevTV part 1 and 2 videos.
i get the following error in Visual Studio 2013 when i set my debug application to Revit2015.exe
"The program '[11364] Revit.exe' has exited with code -529697949 (0xe06d7363) 'Microsoft C++ Exception'."
After i get the error then Revit closes down. i have to manually start the revit to test the addins created.
Thanks in advance.
CCheers
gary
Solved by R.van.den.Bor. Go to Solution.
Thanks R. van den Bor.
the first link worked just fine. just to make it easier for others if come across this issue..
You need to check "Use Managed Compatibility Mode"
Tools > Options > Debugging > General
Cheers 🙂
So, following all the the links on this subject, I'm having a bizarre result following the "Hello World" tutorial.
I've changed "Use manage combatibility mode" per discussion here;
When I use (F5) to start the debugger, Revit opens as expected, then I'm thrown a debug exception immediately after the prompt for an "untrustworthy publisher".
The debugger returns this message;
When I launch Revit manually, my "Add in" loads correctly and functions per expected;
