I have some wall types which contains wall sweep. Now when i am adding walls with add wall sweep in way, i have shown in attached image file. Sweep is not getting cut autometically at intersection of wall.
Is there any option where it will cut autometically when wall intersect?
Thank You!
Nitesh Panchal
Solved by alan.quinn. Go to Solution.
Please review the following link for information on Wall Sweeps:
Revit 2014: Wall Sweeps
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-54122AE4-F009-42FB-8670-D665598A5A46
I hope this helps and thanks for posting.
