Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Current level
3 REPLIES 3
sanjaymann
1637 Views, 3 Replies
Current level
How do I get the currently selected level.
Thanks & Regards
3 REPLIES 3
jeremytammik
in reply to: sanjaymann
active document > current view > level?
check using RevitLookup.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
sanjaymann
in reply to: jeremytammik
The following code will give you the level:
doc.ActiveView.GenLevel.Name
Thanks & Regards
jeremytammik
Thank you for sharing!
Jeremy Tammik
The Building Coder
Rail Community
