Revit API
Revit API
41 Kudos
Post 1 of 4
Creating element in updater typeof "GetChangeTypeElementAddition"
230 Views, 3 Replies
11-27-2012 11:16 PM
Hi all Revit API masters :-)
Doesn anyone have an experience in following situation?
I have an updater which is triggered by element additions (Element::GetChangeTypeElementAddition()). Within the Execute of that updater an another element is created (a tag element).
In previous Revit release this again caused triggering of updater(s) of "addition" type. But seems that in Revit 2013 it's not the case anymore(?). It seems that elements (at least tags) added inside the addition updater doesnt' cause further triggering of similar updaters.
Can anyone confirm or disprove this?
Thanks!
Dear Olli,
Thank you for reporting this. I submitted a change request SPR #234298 [Updater difference between 2012/2013] on your behalf for further exploration.
ADN Support Specialist
46 Kudos
Post 2 of 4
Re: Creating element in updater typeof "GetChangeTypeElementAddition"
12-13-2012 09:50 AM in reply to: ollikat
This is not listed on the "Revit Platform API Changes and Additions.docx" for 2013, so if you believe anything changed, then we need to investigate deeper. Can you provide more information or sample code on it? Please don't share confidential information or, if you are a ADN member, then you can log a case.
Augusto Goncalves
Autodesk Developer Network
92 Kudos
Post 3 of 4
01-21-2013 08:38 AM in reply to: augusto.goncalves
Dear Olli,
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
41 Kudos
Post 4 of 4
01-21-2013 09:26 PM in reply to: jeremytammik
Any time Jeremy :-)
I marked this as solved, although the issue stille exists, but in scope of this forum, this question is dealt now.
Thank you too!
