Hi
I would like to create the rebar using API 2014. I found some sdk sample which is not meet my requirement. I need to create the rebar on beam(for example I may selected the beam) and inout is (Rebar bar 6R) Shape(Stirrup - T1). For your reference i have attached job file.
Regards
We have one command showing how to create rebars for column. I think the method should be similar to create rebars for beams.
The attached c# code file also contains the command to create a new rebar shape.
Hope this helps.
Possible to share the all the codes since the attached code has compilation error. For instance, no RstUtils class code is given.
