Revit API
Distinguished Contributor
RocksterB
Message 11 of 15 (234 Views)
Re: Create Line Pattern Type?
11-18-2012 08:39 AM in reply to: mfleming.stantec
Joe, how do I load the line pattern code you've provided into Revit?
Member
cmckeown
Message 12 of 15 (186 Views)
04-14-2013 08:40 PM in reply to: mfleming.stantec
Am i correct in saying you can not set line pattern to a category?
Regards
Chris
ADN Support Specialist
jeremytammik
Message 13 of 15 (180 Views)
04-15-2013 08:11 AM in reply to: cmckeown
Dear Chris,
If you can do it through the user interface, it is probably possible programmatically as well, and vice versa. Is it possible in the UI?
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
chris.j.mckeown
Message 14 of 15 (174 Views)
04-15-2013 04:36 PM in reply to: RocksterB
Hi Jeremy,
I found the below post on the Autodesk site just after I posted this question...
http://forums.autodesk.com/t5/Autodesk-Revit-API/Line-Patterns/m-p/3110368/highlight/true#M2163
Yes it is possible via the UI but according to Saikat it is not possible via API yet.
I haven't checked 2014 yet. I notice in 2011 they had the method to set it but must have caused an error, so they (the factory) removed it in 2012/3 never to be seen again?
Regards
Chris
Dale.Bartlett
Message 15 of 15 (52 Views)
06-12-2014 12:20 AM in reply to: Joe.Ye
Hi Joe, Do you have similar code to delete line patterns? Dale
