I dont want a how to on this, i simply want to know if it can be done. Yes i know that there is software available that will renumber the mark value. Our purpose is to create an api that you select a run of pipework or ductwork that has been split up into manufactured lengths and assign an incremented number to each piece specific to its sheet. So that in the next sheet the number will start at 1 again, thus creating multiple warnings of duplicate marks.
Our tag will be a mulicategory tag that will be assgned to a text shared paramater.
Can this be achieved?
Solved by sanjaymann. Go to Solution.
Start a tarnsaction.Declare a counter as double and set it to 0. start looping all the elements on encountring the first element set its parameter mark value to counter and increment the counter by one.
Commit the transaction.
All done.
Thanks & Regards
Dear Craigjonnson,
Thank you for your query.
As you can deduce from Sanjaymann's friendly and helpful answer, the short answer to your question is:
Yes, this can definitely be achieved programmatically.
I hope this helps.
Best regards,
Jeremy
Hi Sanjayman,
Thank you very much for your detailed reply. I am just getting into the development API side of revit, but I do like to figure these things out. That's half of the fun. However, your reply has allowed myself to fast track through this process and I appreciate the time you have taken for that.
Regards
Craig J
