Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Correct Parameter Units (Metric)
1 REPLY 1
FreshGroundEarth
482 Views, 1 Reply
Hi there.
I am using an addin currently to interrogate the instance and type parameters of windows.  While the interrogation works, the units come out incoherent.  A 1000mm wide window, comes out as 3.2808........
Both the original template and the window are Metric based.
I need to obviously make sure I get the correct values for length and height, any help most welcome.
I have attached a copy of the code as currently written if that helps.
Tags (2)
1 REPLY 1
ollikat
in reply to: FreshGroundEarth
Below is a quotation from some place...can't remember where. But it states quite clearly about this unit mess in Revit.
Note: Since Revit stores lengths in feet and other basic quantities in metric units, a derived unit
involving length will be a non-standard unit based on both the Imperial and the Metric
systems. For example, since a force is measured in “mass-length per time squared”, it is
stored in kg-ft / s2.
Rail Community
