Tevion,
Hmm, great question. I don't see a way to grab the specific XYZ points,
but you could probably interpolate them from the column location (X and
Y from FamilyInstance.Location) and the Top Level (+offset) and Base
Level (+offset) for Z. The built-in parameters
"FAMILY_TOP_LEVEL_PARAM", "FAMILY_TOP_LEVEL_OFFSET_PARAM",
"FAMILY_BASE_LEVEL_PARAM", and "FAMILY_BASE_LEVEL_OFFSET_PARAM" should
give you the top and bottom locations, then get the Z value from the
Level.Elevation for the base and top levels.
You could probably write a quick function that you pass a family to and
it returns the XYZ values.
Hope that helps,
-Danny Polkinhorn
WATG
Honolulu
Tevion wrote:
> Hi,
> good idea to create this forum, the API seems to be quite powerful but also quite complex. Simple tasks might get tricky to solve and so the forum might be a good address to ask for help!
> Well, I am looking for a way to get the start and end coordinates (XYZ) of columns out, type Structural Columns. Structural Framing coordinates I get but the columns are family related and that is causing me problems. Maybe someone has an idea how to get those coordinates?
> Thanks,
> Tevion
