Hello
I am recompiling my existing addin to work in Revit 2015. My addin uses the methods
Transform.get_Translation() Transform.get_Rotation()
These static methods are now deprecated in Revit 2015 API. So I need to use the Revit 2015 API versions of these methods.
Are the Revit 2015 API equivalents of the above methods the following?
Transform.CreateTranslation() Transform.CreateRotation()
Solved by ollikat. Go to Solution.
